#119424 05/30/02 04:34 PM
I've been looking at getting a y-pipe, as my main cat is bad and I plan on doing the mystery mod on the precats.
I've heard of some heat problems with the SHO shop and BAT design. Does the Yodude Y have the same problems?
Right now I'm leaning towards the BAT stainless Y because it appears to be a good value, what does everybody think?
don't drink and drive.
Buy a dual inlet single outlet cat from me for $95 and get it installed for cheaper than any of the other options.
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
hey, sounds good. $95 shipped? dual 2" into single 2.5"?
Modify your original Y pipe so that you keep the heat shieding but eliminate the crappy Y-merge joint.
Scott
