I just got a pretty brand spankin new 99 contour ,Sport Version, and know very little about what can be done to it. I already am putting a cold air induction kit on it (homemade, they work). I wanted to know how much in the way of performance upgrades I could add on for $500 or less. It has the 2.5 litre engine (170 hp).
any help would be apperciated
1999 Ford Contour Sport
2001 Smart Parts Impulse
and both of em kick arse
o and I know nothing about cars
congrats and welcome to the site smile u should have fun with your tour...look around the site and u'll find lots of options on what u can do to it...for 500 u can do cold air and a chip or maybe u can get a decent exhaust system for that although the more popular kits (cat back systems)used by some on this site are more in the 600 range i believe
others can give u more insight...meanwhile just read around and someone will answer any questions that may come up for u
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
Congratulations on the purchase.
If I were you I wouldn't go cat back, (too much money). Just get the muffler and res. replaced with highflow stuff. I got mine done for 250, so you would still have about 250 to play with.
98 MTX V6 SE Sport
KKM
Mangnaflow muffler and res.
KKM intake ($90)
SHO Shop or BAT Y-pipe ($ 250 approx)
used SVT catback ($100 approx)
Dual mode damper from Terry Haines ($135)
Energy front motor mount inserts ($20)
OK, I ran a litte over but these mods will help your car sound better, rev smoother, make more power, and possibly last longer.
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
Excellent choice. I drive the same car, and enjoy her very much. Check out the mods section on the main Contour.org page and check through those particular mods. I really reccommend the dual mode dampner, cold air intake (whichever you choose), Magnaflow resonator p/n 12255, and which ever brand of muffler you like. Custom exhaust and intake are good starts, and the DMD really makes the car run like silk (or a BMW laugh )
'99 Contour SE V6 w/MTX (Black Clearcoat)
'02 Dakota 4.7L V8 2WD X-Cab (Flame Red Clearcoat)
I'll have to along the lines of what Dan Nixon suggested:
intake
SHO y-pipe
SVT exhaust
chip
- Pete - 00 SVT SF/MB - 1522/2150 - DOB 1/12/00
92% says your group-NOT HOT
85% says your either wrong or BLIND
Blackhawk Down did NOT suck
you know who you are.....
