Posts: 42 |
How much would our cars benifit from doing the heads, tb, and the intake manifold.
98 svt -KKM-Bassani-magnecore wires w/+4-
Posts: 59 |
it all depends on how much you get it ported but i think that it would help out pretty good i could be wrong though
Posts: 5,805 |
Not a lot on modern high tech multi valve engines...big old cast iron V8's ..yes.If you talk to race engine builders 'matt' is better than polish...if you mess too much with the '3 Zones' of intake ports you will loose performance.....
Posts: 653 |
Originally posted by Terry Haines: Not a lot on modern high tech multi valve engines...big old cast iron V8's ..yes.If you talk to race engine builders 'matt' is better than polish...if you mess too much with the '3 Zones' of intake ports you will loose performance..... Terry, can you explain in a little more detail what 'matt' is? Thanks, Mike
I have a dream, and that is a 69 Boss 302 with Jules Asner in it. Current - 2002 Chevy Silverado Former - 98 SVT E0 T-Red 4/4/97 #173 of 6535(so long girl, you'll be missed)
Posts: 5,805 |
'Matt' finish Vs polish........
Posts: 653 |
Is this the same type finish that you'd get your pictures developed in? Where it's slightly pitted v. very smooth? If so, I thought that the smoother the surface, the better it is, because turbulent air hurts power.
Please set me straight on this. Thanks, Mike
Posts: 1,003 |
Think of a golf ball- the dimples make it fly farther.
Also, fuel can collect on the port walls if they are smooth which is not a good thing. A slightly rough surface won't allow this. Polishing your exhaust ports though can help cut down on gunk a small amount, but probably not enough to warrant the time/cost.
I thought I read something on NECO's forums where the Leo Capaldi Speedvision Cougar gained around 40+hp with alot of attention to detain in the inlet side of the engine. Heads, manifolds, etc..
Posts: 5,805 |
Every engine builder has 'tricks'..'riblets' 'ratchets' 'golf balls' 'dimples' etc etc...
Posts: 653 |
I see the light now, thanks Alex and Terry. Mike
Posts: 650 |
What type of finish does Xtrude honing leave?
Ohsigmachi '96 GL MTX Zetec SS (SuperSleeper) Suffice it to say my mod list has become so long that it is just ridiculous
