#1603301 07/04/06 02:11 AM
E
E
So...I topped off the brake fluid assuming perhaps that was the reason why my brake light was illuminated, and I was correct to an extent as the light disappeared. I read that the low level in brake fluid could be the result of worn brake pads, but they are all rather new. Then, 4 days later I noticed globby stains all over the driveway (causing my fathers subsequent rage) small and big blobs, they seemed to originate around the wheel locations, all these blobs of brake fluid I suppose. So, today I was driving and, of course, the brake light came on again, I pulled over, checked, and indeed, the fluid level dropped once again drastically and here I am now. So, Can someone please tell me why these leaks (leak) happened, a possible price range for a repair(I'M A POOR STUDENT!!!), and what parts and location I should look at specifically under the vehicle to locate the leaks. Thanks in advance! Much respect!
-JD. 1996/V6/LX. Killer Bass, & A Few Other Mods.
#1603302 07/04/06 02:36 AM
F
F
***Your car is not safe to drive***
The rear brake lines may have rusted out (just happened on my sister's Mystique), drum brake wheel cylinder(s) have failed or disc brake piston is leaking. If it is all 4 wheels leaking, maybe the bleeders are loose. I would expect to pay a couple hundred US dollars (mostly labor) to fix your car, less if it is just bleeders. You could probably look under the car with a bright flashlight around the back sides of the brakes and anywhere there is a spot on the ground, and find the leak.
