#1602475 07/02/06 03:19 AM
I
intOx Offline OP
I
so before i hooked up my subs to my amp, i used a battery and tested to make sure that both of the subs worked and they did....when i hooked them up to the amp only my left one worked...so im like ok maybe i wired it wrong (but i know i didnt) so i played with the wires and i got both to work. i take of to my buddy's and when i get there one sub isnt hitting at all. when i got back home i tested it with a battery D battery again and it didnt work... i changed the wires that ran to that sub and i still didnt get any luck.
any ideas as to what could have happened???? it's boggling the $H1T out of my mind and im not gonna be able to sleep unless i strap c4 to that woofer and blow it back to hell.
I
intOx Offline OP
I
bump
ideas anyone?
F
F
You found a bad woofer voice coil, hopefully you can return it? You could have a bad solder joint at the terminals.
Moderated by  dnewma04_dup1
