Posts: 12 |
I did the mystery mod about 2 weeks ago and reset the computer at the same time. The check engine light did not come on for a week after that. I reset the computer again and it took another week for it to come on. Did it take that long for the light to come on for anyone else or may there be another problem. Thanks
Ground Control Coilovers Koni Adjustable struts Sub-frame connectors Slotted rotors Carbon Fibre pads Stainless Steel Braided line KKM Intake Pro-Flow Mass-air Meter 22mm rear sway bar Polyurethane motor mount inserts
Posts: 154 |
Do you have the mil eliminators in downstream? Not having them might cause a cel. I didn't have any cel after I did mine, but I have a 95, and don't have the extra 02 sensors downstream.
95 mystique LS, High Output Cougar S (SVT) 2.5L engine & MTX75
Posts: 1,428 |
No MIL eliminators on an OBD2 car will cause the CEL to come on!
Posts: 3,562 |
The reason it takes a week to set each time is that an OBD-II driving cycle takes so long to complete. It's not a certain amount of miles, it's a certain amount of cold starts, warm starts, hot starts, coasting, throttle positions, etc... Get the MIL elminators or make some.
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 3,237 |
Either no MIL's or a smashed upper O2 sensor (from the good ole air-hammer) - I have seen two of those now!
