E
E
I wondering if there was something I could do toget my engine to decelerate faster.
Underdrive pullies, and lightweight flywheels are about the only things that will make you rev faster, or drop revs faster... that I can think of.
If you're reffering to how revs seem to "hang" for a second or two after you blip the throttle, take the time and search around for the "throttle hang fix" or "th fix". There is alot of info on it and how to fix it.
Does that help, or are you referring to something else??
I think engine braking has to do with torq...our cars don't have alot of torq so it doesn't deccelerate quickly. If thats not what you rtalking about than the above is the other reason.
Josh
Aka Spectra SVT
02 Dark Highland Green F-150 XLT
Mods: Gunrack and cowboy boots
E
E
Thanks, I a drilled copper top and it works fine. Next thing is this mystery mod. What exactly is that?
just use the reverse thrusters wink
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
or swap in a diesel, lol. laugh
95 Contour SE ATX V6
"Cracked" Secondaries
DMD Installed
SVT Brakes
