Posts: 178 |
I see alot of people removing the resonator off their contour.. I notice my car even when im going fast or accelerating quickly its QUIET how much louder will removing this thing make the car? do you gain ANYTHING off it? or very litte? tnx for info
Posts: 8 |
After I had the resonator removed from my car I noticed a small gain in mid range power and a noticable gain above 5500. The sound is definately more on the raspy side (but not to bad). Hell aside from the K&N filter that was the best $20 I've spend on my car. My next step is new muffs and a "true" dual exhaust.
YOU LIFT YOU LOOSE!
Posts: 178 |
so the resonator is the bigass canister closest to the muffler im assuming its almost as big as the muffler just cut the pipes and put in a straight peice of pipe?
Posts: 460 |
Right! It will sound really "Ricey" when cold... Just a warning! I liked it when I had the stock exhaust.
Po-Jay
Ghetto Mods Galore! Quaife-CenterForce Clutch-Butterflies Rmvd and Replaced again-Bassani Exhaust w/custom "Y"-Pipe-33% of Mystery Mod-Pro M 75MM MAF-BNoon Optimized SVT TB-B+M Short Throw-ES Front Engine Mount-Some Aesthetic Crap- Blood,Sweat,Tears Do I hear the Fat Lady singing? 98 E0 Silver Frost (Is there any other color?) 172HP 149TQ W/Bad A/F Mix
Posts: 178 |
hmm loud ricey or nice ricey? i dont want it to sound like i have a 6" fart pipe on a honda
Posts: 1,355 |
Originally posted by Putz: hmm loud ricey or nice ricey?
i dont want it to sound like i have a 6" fart pipe on a hondaIt's not that bad, But like stated above,when it's cold, it's pretty bad. But once the exhaust warms up it's ine, just for a few mins it's like that. It's well $30 in my opinion. If your quoted any more then that, go elsewhere.
Simon W. Las Vegas. 96 SE V6 MTX Tereador Red (1st Blown Engine, better be the last!) 1999 SVT Engine SVT Exhaust w/custom DTM Tips and optimized Y-pipe and no Res (thanks to Po-Jay!). LSD Quaife(thanks to Terry!), SCA CAI w/KKM, Grizzly clutch, FMS 9mm wires, Airknights custom short shifter.
"You can only get more rice at one time by ordering Chinese" - Davo7SVT "it's only nuts and bolts" - Terry Haines "Drive it like you stole it" - Me!
Posts: 446 |
I just did it a week ago. It does sound raspy when you first start it up but like everyone else has said it sounds good when its warmed up. I'd say go for it no matter what. Its cheap, easy, and relatively quick. Just as long as u don't mind a little drone when u let off the gas and the back pressure is released. Hope this helped. ><>David<><
"this world has nothing to offer, come back soon." luti-kriss throwing myself an act of my own violation '98 Black SVT- 3949/6535 8k miles ticked away, Eibach springs, Koni Struts, SHOShop CAI, Ford 9mm racing wires, deleted res., lead foot...more to come. http://community.webshots.com/user/svtminiflea
Posts: 73 |
I've been deciding whether or not to do this for three years now and I finally had it done Friday, along with some 3 1/2 inch stainless steel tips. I replaced it with a Magnaflow resonator from Stazi. I have the SVT dual exhaust, also. I am VERY impressed with the sound. As soon as I start it up it let's out a much louder snarl. Nothing ricey here. Initial launches feel almost the same, but mid-range and high RPM's are greatly improved. I really didn't expect to gain any ponies, but it has to be quicker. I also have the Superchip installed for a few years now and I was able to rev to 7,000 in first gear, but then it would shift into second. NOW, it rev's to 7,500, the redline (not a good thing to do...don't do this often), but anyway, it scared the hell out of me last night when I stepped on it to test the new resonator and the needle jumped to 7,500 in first gear. Anyone else experience this? Is this normal? I mean, I know quite a bit about mods, but I can't figure why it revs high besides the fact that the exhaust flows better now. Is the stock res. THAT restrictive?  Anyway, that's my lastest experience with my newest mod. Rob
1999 SE Sport, Medium Steel Blue (CEG member since 2/98) SVT Dual Exhaust w/ Magnaflow res. and 3 1/2" SS Tips, E0 SVT Rims w/ Kumho 225/50ZR-16's, Superchip, SVT KKM, SVT Side Skirts, SVT front and rear bumpers, BNM white-faced gauges w/ blue glow, Carbon Fiber Shift Knob, no intake resonator, BAT Big Brake Kit C, Roger R dead pedal *DEFINITE future mods, by 7/02* wider rims, Y-pipe, revised exhaust, SVT TB, SVT Upper Intake w/ powder coating (GO BNM!)
Posts: 226 |
Little raspy/ricey for about 2 minnutes than it goes away. you wont be disapointed. about a 20-30 minnute job. If you CANNOT tolerate any rasp, you can also get a high flow resonator put in instead of just the regular straight pipe.
1999 contour se sport- black mtx -Duratec v6 -dual exhaust -no resonator -kkm induction system -one loud stereo -35% window tint -18' Enkei CDR9's on Kumho Ecsta Supras. -Audi A6 Sidemarkers (Coming Soon, Very Soon.) -SVT front and rear bumper.
2002 Passat V6 GLX 4Motion
Posts: 316 |
I always say never remove the resonator, only replace it with a high flowing bullet muffler. I chose Dynomax Ultraflow. Magnaflow, Edelbrock, and others work also. Rasp is horrible without one.
98 T-Red Contour LX V6 Mtx 106k miles 9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
