Posts: 349 |
Can anyone who has the Fidanzia Flywheel installed tell me thier before/after impressions/opinions of this flywheel on thier car?
Evan Groenke 1999 Silver Frost SVT #1919 183.9hp 163.7lb/ft tq @ the wheels Now bitter at Ford
Posts: 154 |
WOW!! That's about all I can say, the car revs so fast, and it puts the engine in it's powerband so much quicker. I highly reccomend a Flywheel as a must mod for everybody. Wether you use the Fidanza or a steel flywheel, it is a must mod.
2001 Mercury Cougar Aerogear WideBody Kit, Aerogear Carbon Fiber Hood 3.0 Hybrid 251hp and 229tq at the front wheels Eibach springs, Koni Stuts, Aussie Bar, ST200 R Strut bar, OMP front Strut bar, 19" RPM's 235/35-19 Nitto 555's All Alpine System - IVA-C801, DHA-s680, NVE-N852A, TCS-V430A, TMX-R705, TME-M580 x2, PXA-H900, MRD-M500 x2, MRV-f540 x2, SPS-0829, SPX-F17t, SPX-17m x2, SWR-1021D x4, RUX-4280 http://www.geocities.com/socal_neco/jimmy.htm
Posts: 89 |
I agree. The fidanza is a great mod and you will notice the difference imediately the first time you drive your car after install. If at all possible do this mod, a new clutch and the quaife at the same time. Install is very expensive, so it is best if you do it all at the same time.
1998 Silver Frost SVT Purchased 01/10/02 Mods so far: -Fidanza aluminum flywheel -Clutch upgrade -Clarion ProAudio system, DSP, 13 Band EQ
Future mods: -Intake upgrade -Performance plug wires -Autolite double platinums -Konig 18 X 7.5 Toxxin's -Koni's and Eibach coil overs -Rockford amps, 3 12" Rockford subs, etc.. (Just needs to be installed)
Posts: 333 |
SWEET!!!! I love it plus i hsve as very light weight clutch in too ( ur racing ) and wow doesthe car rev well and smooth!
Silver 99 SVT It's Stock. Would I LIE?
My cars the Silver one
Posts: 407 |
Any down side folks? Like having to launch at higher rpm's from a stop to get going.
Black 98.5 SVT w/ KKM intake, 73mm MAF, ASP pulley, Optimized stock Y-Pipe, 24mm hollow rear sway bar, Magnaflow resonator, Magnaflow mufflers, Roush springs, KYB struts
Posts: 349 |
Originally posted by LBVSVT: Any down side folks? Like having to launch at higher rpm's from a stop to get going. Good point Lou. Don't you have one sitting at your house right now?
Posts: 407 |
I wish Evan. If I was putting in an LSD I'd do it though ...
Posts: 176 |
Anyone weigh thier's? I thought it wsa 11.5lbs but someone said thiers weighed in at 8lbs Thanks
2000 Roush Cougar MTX MSDS Headers, Rear disc conversion, SVT TB and IM, Custom 2.5" exhaust, Weapon R Dragon w/kkm MAF adaptor, B&M, NR wht gauges
Posts: 650 |
Did you guys get your Fidanza's balanced? I read somewhere that the factory clutch is factory balanced, but the Fidanza doesn't come balanced? Any clarification here?
Ohsigmachi '96 GL MTX Zetec SS (SuperSleeper) Suffice it to say my mod list has become so long that it is just ridiculous
Posts: 563 |
Mine is not balanced but it says in the fidanza documentation that it is CNC machined but not balanced. Lesser weight flywheel lesser to worry about. I have a Ram HD it is also lightweight with cheaper price tag than UR. Unlike the SVT clutch the ram is all or none when you take off. Meaning that it has no springs in the kevlar disk. I guess that is a personal prefrence. Me likey.
Dustyn Red 1998 SVT E1 95 Mustang GT Yeah there both slow New ram clutch for sale Sho shop pullies and belt for sale 30 bucks
