The instructions below should be enough for an indy to perform.
From 1996 Ford CD Manual,
Accelerator Cable
Removal and Installation
Note:
The accelerator cable assembly consists of two cables.
1. On vehicles equipped with 2.0L engine, remove one bolt and two nuts retaining engine intake air resonator to throttle body. Raise engine intake air resonator and place to the side.
2. Remove windshield washer reservoir.
3. Disconnect the accelerator cable at the throttle body throttle lever by removing clip at accelerator cable bracket and removing cable from throttle body lever or quadrant.
4. Disconnect other end of accelerator cable at traction control by removing cover and removing cable from traction control pulley.
5. Disconnect accelerator cable at accelerator pedal and shaft.
6. Remove accelerator cable from dash panel by pushing grommet and accelerator cable through to engine compartment.
7. Disconnect other end of accelerator cable at traction control by removing cable end from traction control pulley.
8. WARNING: NO SURROUNDING ENGINE COMPARTMENT COMPONENTS SUCH AS WIRING OR HOSES MAY CONTACT ANY MOVING MEMBER OF THE ACCELERATOR CONTROLS. ALL VEHICLES ARE TO BE CHECKED FOR PREVENTION OF RETURN TO IDLE MAY OCCUR DURING SLOW REMOVAL OF THE FOOT FROM THE ACCELERATOR PEDAL AND SHAFT STARTING AT THE FULLY DEPRESSED WIDE OPEN THROTTLE POSITION.
To install, reverse Removal procedure and perform accelerator cable adjustments.
Accelerator Pedal and Shaft
1. Disconnect accelerator cable from accelerator pedal and shaft.
2. Remove three nuts retaining accelerator pedal and shaft to dash panel.
3. Remove accelerator pedal and shaft.
4. To install, reverse Removal procedure and make sure accelerator pedal and shaft has no restrictions. Tighten to 15-20 N-m (15-20 lb-ft).
Accelerator Cable Bracket
2. Disconnect speed control cable from throttle body lever or quadrant and accelerator cable bracket.
3. Disconnect accelerator cable from throttle body lever or quadrant.
4. Remove clip and disconnect accelerator cable from accelerator cable bracket.
5. Remove two screws retaining accelerator cable bracket to throttle body on 2.0L engine. Remove three screws retaining accelerator cable bracket to throttle body and intake manifold on 2.5L engine.
6. Remove accelerator cable bracket.
7. To install, reverse Removal procedure.
