Originally posted by m.adair:
Thanks for the input. KKM good for a awhile? Is this because of the filter? What is the advantage of the BAT MAF? Lastly, what is the best retailer to find the KKM at? In stock and ready too ship.
Thanks, Michael
If you plan on doing any exhaust modifications or any more flow modifications at all, the KKM S&B filter size & design will not provide enough flow. The filter design makes it die at higher rpms and the filter size yeild lower gains obviously than a larger filter.
If you search you'll find several posts about this subject.
Again the KKM is a great kit, but its not for someone who plans on modifying their very much. I'm only saying this because I wish I knew this before I bought it. Now I am to the point where I need to buy a new filter, in order to fully take advantage of all my gains.
So why not do it from the start?
Like I said check into the BAT Maf ADAPTER w/ Screen gasket holder (I wouldn't get their filter kits), then look into a 7-9" K&N or AFE filter, and make or buy a heatshield. If you do this you'll have a good building block!
The BAT tubing is a nice design but you can buy the tubing from Home Depot and run your own.
If you do get a larger filter you may have to do some trimming. Again if you run a search I'm sure you'll get plenty of info on this subject.
Hope that helps
