What up all,
I just got my svt parts the other day and have been busy getting the tb polished up and the shaft trimmed down. From what i understand the svt lowers (from a 98 svt) are about 1mm dia larger than the se lowers (98.5 se). So obviously i need to do one of two things:
1.) Pull the heads and have them portmatched to the svt lowers
2.) Have my se lowers blended to match the svt uppers and probably swap or remove the secondaries
This is my only ride at the moment or i would go with option 1 no questions asked. So I'm mainly looking for input on option 2.
Any thoughts?
98 SE
BAT Big Brake Kit "C", Throttle Hang Fix, B&M Shifter, Lightly Cracked Secondaries, BAT Euro Handling Kit, 20% tint, Removed Ding Strips, ES Motor Mount Inserts, Borla CatBack, Apexi SAFC, HighTower Rear Brace, BAT 19mm rear bar, MSDS Headers & Y, AFE 20-35008 filter, ClutchMasters Stage 1, Fidanza FlyWheel, SVT T.B.
====OnOrder====
svt uppers and lowers,
The head ports are cast larger than they need to be and will match the SVT lower just fine. wink
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
Thanx B. smile
I was just looking at the svt uppers and lowers and noticed that even the se upper to lower gasket has port openings a mm or 2 larger than the ports on the svt manifolds, so.... I guess it just comes down to how meticulous you want to be and how much free time you have anyway...
98 SE
====OnOrder====
