Posts: 674 |
Does anyone know what the seat covers on our cars are made of, specifically 98+? I say this because in my dad's 95, it has the patterned cloth all over, where as in my 98 the pattern is only down the middle and a different fabric lines the sides and headrest.
I'm interested to know because I'd like to find out if they would shrink in the washing machine and make it difficult to put them back on.
Posts: 1,047 |
You realize to machine wash the covers you need to tear down the seats and rebuild them again,which is definetly waaaaay more trouble than it's worth for you. They aren't just slipped over the foam,they're tied down with hog rings,velcro and plastic push pins.
I've torn down a set of rear seats from a '98 Mystique and you definetly won't enjoy yourself putting them back together,and I can only imagine the front seats will be more of a pain in the butt.
I build Chrysler seats for a living,so if you don't know what you're doing,don't do it. I wouldn't run the risk of machine washing the covers anyways. The covers themselves,atleast the ones I build,do expand and contract from heat and cold.
If you're bent up on washing the seats,why don't you just use an upholstery cleaner????
'95 CGL ZMTX - DOB: 8/94 - Daily Driver - 271k & counting - Ractive muffler,MSD ignition coil,KEM 8mm wires,Pre98 SE 7 spoke rims,KVR CF brake pads,Post98 sail panels,Sony Xplod HU,Pioneer 3-way 6x9's
'89 Mazda B2200 - Under Construction
Posts: 674 |
Yeah, upholstry cleaner is an idea as well. I just figured a good machine wash would be better. I've already got a set of hog ring pliers on the way, and I have nothing to do all day for an indefinite amount of time. I just figured for dying the center parts, having the seat covers off and properly washed would yield better results.
Posts: 674 |
theres always these
ebay seat covers
Posts: 3,637 |
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 674 |
eh..I used that duplicolor vinyl and fabric spray on a sock...doesn't seem like it will hold up on high rub areas
Posts: 498 |
duplicolor vinyl and fabric paint isnt going to work on seats, its already starting to fade (rub off) on my driverside door panel (but I only put 2-3 heavy coats on).. probably need more like 6-7
96' ATX Zetec- stock
96' ATX Zetec- Modded
Kenwood KDC-319
5.75"-2 MTX 12's
Roady XT
Custom door panels
Mystique Cluster/oil pressure
Getting repainted(in primer)
Pre98 Lip
SE skirts
Mystique front lip
dingless
badgeless
Posts: 1,047 |
What are you doing,wanting to change the colour of the interior? Don't spray the seats with fabric dye,that'll look like crap. Your best bet is go find some seats from a wreckers.
I had cloth seats in my Mystique and found an indentical Mystique like mine at a wreckers with a leather interior and $350 (Cdn) later,the front and back seats and all 4 door panels with the leather inserts were mine. However,they were already the same colour as my interior.
Posts: 2,086 |
Either steam clean like said above or use a carpet cleaner or tuff stuff.
I have a can of this stuff and it works wonders.
Jason G.
Born: 11/96
Posts: 2,857 |
Originally posted by Mystique97: Either steam clean like said above or use a carpet cleaner or tuff stuff.
yep tuff stuff rocks! been using it for years
new,new ride!
'99 svt
black/mnb
'95 mustang gt sold!
'98 svt #800 sold!
