If you still have a hoodliner, remove it.
Otherwise, you may have to insert a flexible hose section somewhere, similar to the one you removed when you went to the "hard" pipe.
I have the ITG filter and even without the hoodliner, it appears that a slight bend is necessary in order for everything to close.
