Posts: 837 |
I just got a new deck and I'm not getting any sound at all from the left speakers. I have checked the settings in the deck but its not that.
I guessing its a wiring thing, but I though it weird I would mess up both the left speakers?
Help?
CSVT
Feels Like Heaven
Goes Like Hell
Profile
Posts: 853 |
Some HU will go into protection mode and shut down when something is not right. I wonder if only one side of the amp would or could shut down because of an issue?
98.5 Black SVT with 34k miles Build #5683 Born on 4\15\1998
WR Headers GMK CAI
Blaupunkt system fiberglass tweeter pods
L.E.D. tail lights in the works
Posts: 5 |
I am having the same problem! I have a pioneer HU. Do you still have the factory amplifier powering the speakers? If anyone coould help with this that would be great. mike
Posts: 498 |
mine does this sometimes, i have to shut the car off then turn it back on and then its fine, wtf?
all the wires are fine and i don't have a factory amp.
96' ATX Zetec- stock
96' ATX Zetec- Modded
Kenwood KDC-319
5.75"-2 MTX 12's
Roady XT
Custom door panels
Mystique Cluster/oil pressure
Getting repainted(in primer)
Pre98 Lip
SE skirts
Mystique front lip
dingless
badgeless
Posts: 979 |
Occasionally my front driver speaker doesn't produce sound when I first get into the car. I turn up the volume, it works. Also, my rear passenger speaker cuts out sometimes.
I thinks its a fluke with the cars wiring.
My ride(Cardomain link) :
'95 Contour 16V Zetec DOHC, Teal , ATX
Born on Sep. 4, 1995
86+ miles
*LEDs mods are on their way!*
Posts: 837 |
I don't have the factory amp, I have the bypass harness installed.
Either way I fixed the problem. The pins going from the aftermarket harness (the black square plug) were not lining up with the factory hookup in the dash.
You can see if you have the same problem by pulling the pins out of the aftermarket square connector and place them in the correct location in the factory connection. If the speakers now work, then the pins simply need to be bent to line up with the factory connection.
CSVT
Feels Like Heaven
Goes Like Hell
Profile
Posts: 8 |
I have the exact same problem with my '98 SVT Contour. Left speakers don't work ever since I got it. It has a Sony CD player, everything else is stock.
Chris Caselli
'67 Mustang Fastback project car
'98 SVT Contour daily driver
Posts: 5,854 |
i used to have the same problem with my stock HU. It went away when i ripped it and the stock amp out. I dunno which one was the problem though.
1999 Silver Frost SVT
#609 of 2760
Posts: 58 |
I have an issue along the same lines as this. I have an Alpine HU, and the left/front speaker does not push as much sound as the rest.
Posts: 217 |
I have the same problem with my car, hmm wonder what it is.
2000 svt contour
1996 oldsmobile eighty-eight
