Posts: 491 |
As the topic states, I'm looking at adding nitrous to my 1997 Contour GL. Looking at the Zex universal and Venon VCN-1000. I know Venom has better safegaurds, and I know zex is easier to install. I'm wondering what others had and their opinions are? I'm looking to run a small shot (~50). What other mods need to be done to ensure safe usage? Currently my only performance mods are CTA CAI and 2.25" cat-back exhaust. Can I run a chip with nitrous? Is it beneficial to have a chip custom burned for nitrous?
I have lots of questions so any info would be helpful.
1997 GL Sport MTX, Soon to be the fastest proven Zetec around.
Posts: 592 |
if you only want a 50hp shot. Zex. Cheap, Easy & 'Safe'
Ryan 98.5 Silver Frost Tour SVT 5979/6535 Born: May 15, 1998 Some Mods, still not fast enough.. 90 Black SHO
SVT Performance.Com
Posts: 128 |
You can also get NOS system, it will work good, I got one on my car. Well fell free to ask me about it more, pm me or email. Good luck.
98 GREEN SE RACTIVE. 75 NOS. KONIG WHEELS. ST200 UPPER INTAKE MANIFOLD. SVT TB. BOCH +4 PLUGS. 9MM PLUG WIRES. AUDIOBAHN, ALPINE, PLS2 INSIDE. AUTO METER. SVT BODY KIT. SVT GAUGE CLUSTER WITH INDIGLOW GAUGES. MORE COMING SOON.
Posts: 32 |
The Zex kit has been working great for me (had it about one month).
Gotta love the torque.
Installation took me about 4 hours (I'm a slow worker), start to finish... VERY easy. As for other mods to make it more safe; I put a larger fuel pump on mine (mainly because the stock pump was going out), and make sure you use only copper-core plugs, preferrably 1-2 heat stages colder than your stock plugs. If you want to use a chip with the nitrous, it MUST be programmed to leave the timing alone (or retard it if you go above 75HP shot), and should also make the car run rich at WOT. The standard performance chip programs will NOT be a good idea with nitrous... they advance the timing, and adjust a/f curves for more power (closer to lean). FWIW, the LPM in my SHO allows the computer more timing control, it runs VERY rich at WOT, and also controls a few other nice little things, such as making the engine fan come on at a lower temperature, to keep the engine running cooler.
Posts: 25 |
Got any links for the Zex kit?
Also what does WOT stand for?
Thanks
"The Punch" 99 Torreador SVT 1393 of 2760 KKM True Rev SHO Y-pipe w/cat, NoRes PIAA 510 fogs w/parking RoyalPurple Synthetic In my living room: SHO UDP
"Because sometimes when I look at my car from the back... It looks like a PUUUNCH"
Posts: 76 |
wide open throttle. call up speedpeople.com you should be able to find their number in either super street or SCC. both im sure you have laying around your house! ask for dominic. he just installed a zex on a contour and could tell you some things to look for.
99 Silver Frost SVT
65mm T/B, Aussie Pipe, 8" AFE filter, Fogs & Knauberized, Res Removed, AutoMeter Pro ShiftLite, Ground Controls, Konis, Aussie Bar, Magnaflows (uninstalled), Mirko Splitter (3" off the ground and beat to HE**)
"give 'er, eh!"
Posts: 491 |
Here's what I decided;
1) Going with the ZEX smart kit, #82011 I believe. 2) Getting a superchips flip chip a) one program for performance b) another program for nitrous 3) 50HP boost to start
Posts: 32 |
I got my Zex from Harley Nace Motorsports They have good prices, and the service was pretty quick. I finally hit the track tonight with the nitrous... Here are the numbers from my best run: R/T = .614 60' = 2.358 330 = 6.307 1/8 = 9.547 MPH = 75.91 1000 = 12.318 1/4 = 14.647 MPH = 97.22 FYI.. Bandimere is about 5800 feet above sea level... NHRA altitude corrections for my time equate to a 13.64 @ 104.33! Assuming I've done my math correct, that puts my HP for my best run at about 268 fwhp. Yippee!!! Okay.. so I didn\'t do the math myself... Click Here for Car Math
