Im having an oil leak issue.Its been fin up until I changed the oil. Normally I ran 6qts of oil. Now with the 2qt accusump. Total of 8qts. It runs fine until i hit the switch to accivate the accusump. BTW it has a solinoid that opens automatically with a hit of a button. Should i be running less oil? Could this be the problem? Cause i odnt get any leaks with it off and oil pressure is normal.
