#1592261 06/16/06 10:24 PM
Instrument panel lights are out. I checked the fuse under the dash and it's fine. Also the little dimmer dial on the dash wont even move. Any ideas?
Silver 98 SVT Contour E0 #4121 Reborn with 3L 6/03 Dyno: Max Horse Power= 194.1 Max Torque= 184.8 http://www.geocities.com/speeddemons19 Also at www.cardomain.com/memberpage/561067
Have you check the to see if the rear lights are working? If it is not working, then the headlamp switch is broken.
If it is working, the dimmer switch may be broken (stuck on off) or the wiring came out.
Rear lights work. The dimmer switch wont move, obviously broken some how. I dont even use it, dont know how it would break. But it is stuck in the high position unless it just doesnt matter where the dimmer wheel is.
