Posts: 22 |
My last post didn't really convey the message I was trying to put out. Bassani exhaust and all these other systems are nice and very expensive, but I'm just trying to say they still don't allow the duratec to exhale enough. The power gains I got were a slap across the face. Once the computer calibrated that there was no longer a sock in it's mouth, and now three inch pipe to put out all that exhaust, the power is amazing. I'm sure were talking about 11 to 14 hp gains. The engine doesn't put out power through winding up or after 3200 - 3400 rpms, it's now very consistent. If you're about 16 or 19 years of age (I'm 18), go to highschool and could care less what others think, this may be the cheap mod for you. I only paid $170, not $1000, and my car now sounds like a Subaru rally car or a 5.0 running straight pipes. Best of all, NO RASSSNNNHHHSP. This system requires no mufflers, just the stock tips and a flowmaster Y-pipe. I will post pictures later and try to get a Dyno as soon as possible. I don't have a chip, just a K&N filter. K&N filters are bad by the way. They release fibers that get caught in the MAF and burn it out.
Posts: 3,248 |
Well not to be to blunt but none of what you says makes sensce. But show me a pre/post dyno and I will believe..
K&N fibers???? Too much oil may go to the MAF if you overoil.
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 149 |
Originally posted by EuropeanConnection: I don't have a chip, just a K&N filter. K&N filters are bad by the way. They release fibers that get caught in the MAF and burn it out. If a K/N is so bad, why do you use one? Also, a 5.0 with straight pipes and a subaru rally car have two very different sounds, or do you mean the sounds combined? Hopefully your combo does work well, It just sounds like there are too many diameter changes to be an effective exhaust. Getting a Dyno plot would be very good. Good luck
Mark
00 svt tour- K/N filter, SHO SHOP Y pipe, 2 1/2" back to rear Y, improved tunes.
91 sho- Hi flow Y pipe, 2 1/2" exhaust, edlebrock rpm series 2 1/2" muffs, modified intake, K/N filter, modified manifold, 190 lph fuel pump, magnacor wires, ford double platinum plugs, underdrive pullies, custom LPM, 8 pound aluminum flywheel, hi revs race duel diaphragm kevlar clutch, solid torque limiters, poly bushings evrywhere, heavy duty subframe bushings, heavy duty engine and trans mounts, subframe connectors, front and rear strut tower braces, eibach springs, tokico struts, camber ajustment plates, light weight swaybar end links, cross drilled rotors, carbon fiber pads, 225/55/16 SP 5000's, redline water weter, redline trans fluid, mobil 1 synthetic oil, police grill and the need for speed!!! It's a chronic disease.
Posts: 2,847 |
Let me clarify something. You say you have 3" pipe all the way back with no mufflers, no 3rd cat and stock tips and absolutely no rasp?
I find this very hard to believe. With my Bassani and Off-road SHO y-pipe I had enough rasp to choke a Horse! It was absolutely unbearable! Now even with a resonator in place, I am still considering a larger resonator! I am 23 and enjoy a loud exhaust, but even I have to draw a line somewhere!
Posts: 22 |
Well, if you want me to get technical then I will. The three inch exhaust starts at the what I believe is the last cat since someone mentioned there were three which is right behinf the tranny. However, I believe one of the three cats you thought was a cat is actually a collector. But listen here, you can't have a total of six inches of exhaust (considering the dual exhaust)as you do need some back pressure or you will blow seals and what not. So, the three inches becomes 2.5 inches after the flowmaster y-pipe which is located right before the independent suspension for a total of 5 inches of exhaust clearance for fumes. The sound is much more that of a rally car. I swear to God...no rasp. By definition rasp is an awful sound like that of someone in your back seat blowing through a trumpet all day and rattling a can of marbles. This systems' sound is identical to that of some top rally cars. If you were to get headers ... oh my! The stock exhaust manifolds are as ugly as they get.
Posts: 5,805 |
Please explain the 'no back pressure will blow seals and what not'....this is a new one on me?
Posts: 3,636 |
Originally posted by Terry Haines: Please explain the 'no back pressure will blow seals and what not'....this is a new one on me? He probably means the seals on his wallet TB
Tony Boner Personal: 98cdw27@charter.net Work: tony.boner@sun.com Saving the computer world from WinBloze as Unix/Solaris/Java Guru http://www.sun.com 1998 Contour SVT Pre-E1 618/6535 Born On Date: 4/30/1997 Now with Aussie Bar induced mild oversteer.
Posts: 22 |
Hey man, I'm a repeating-Tom. This is what I was told at the exhaust shop. I'm sorry I don't really know anyone who has knowledge like many on this website, but I'm only tellin' what I heard. Since you seem to think I don't know what I'm talking about then tell me what would happen? Also, fill me in, since I think you own a differential company, what a PCM would do for our engines. Is there something out there that allows for someone to change the air fuel mixture besides a chip?
Posts: 674 |
Alot of people (TOM) will say a lot of things when they know they can get your buying dollar.  just my 2 cents
99 SVT Black/Tan #1311/2760 Born 3/2/99 17x7.5 Momo Racers yoko A520's, Loud Beats,KKM,Bullet Fuel door,Fog Fix & 885's,9005 Silverstars, RichBrook CF Knob.
Posts: 253 |
Hmmm... I guess I may be wrong, but it sounds like someone needs to put the pipe down and walk away...
don't drink and drive.
