Posts: 31 |
Another Escort question for y'all so thanks in advance.
Looking to remove and clean the throttle body on a 94 Ecort 1.9 liter but have read and heard that most cleaners will damage the finsih inside Ford throttle bodies. What do y'all use/suggest.
Thanks
Posts: 6,910 |
the coating that is suppose to prevent buildup on the throttle body plate? I think most just don't worry about it, they do sell throttle body cleaner that might be safe to use but I am not sure off hand
- 95 Mystique LS - Zetec/5spd
Posts: 853 |
Originally posted by BrApple: the coating that is suppose to prevent buildup on the throttle body plate?
Well since it needs cleaning because of the build up on it then i say that coating didn't do its job. So who needs it
98.5 Black SVT with 34k miles Build #5683 Born on 4\15\1998
WR Headers GMK CAI
Blaupunkt system fiberglass tweeter pods
L.E.D. tail lights in the works
Posts: 1,029 |
What is so special about the finish on Ford Throttle bodies? I used Berryman's on mine(  ), and have had no issues from it. Did I do something bad?
Scott
Mabe I WILL be Phil.
1999 Contour SVT, Tropic Green
BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
Posts: 31 |
good point onthe coating not doing its job. I guess at 130k miles, if Ihave to do this again in 60k miles instead of 130, I'll be okay.
Thanks
Posts: 23 |
Berryman's B12.
Let the engine 'sip' one can (of Berryman's) thru' a vacuum line and, when the can is almost empty, let it glug it so that the engine DOES conk out.
Then let the car sit 'with this glomp of B12' IN the engine, UIM area, etc.) for at least an hour -- or better ...overnight.
Then (the next morning) start the car. The B12 -- given enough time -- turns carbon into a sort of 'powder' (which is why you let it sit overnight!) ...and this then is easily dissipated out the exhaust. Net result -- your UIM etc. is clear of carbon.
For 'continual' protection -- put a can of either Seafoam or B12 in the gas tank 'every other fillup'.
For super duper anti-carbon-protection -- use Lucas 'gas additive' (in translucent plastic bottles).
Gerry
1997 Ford Contour SE V6
K+N
Michelin MXV4's
95,000 miles
Posts: 853 |
I can just imagine how this affects the Pre cats and main cat.
WR Headers GMK CAI
