but i was thinking about how dead it was in here, so here is a pic from NED from 3 weeks ago.
turns out my clutch was slipping slightly under full boost, so I just got a spec 3, maybe i can run better!
Jeff
00 SVT #985 Silver Frost 89 Mustang GT TT -410.6hp/460.7trq (couldnt pull past 5k-lean) 12.77 @106 Before turbos, 12.82 @120.12 With them -95 Contour GL, 140K FREE! -WPI FSAE 05'-06', build a race car, get school credit
E
E
sweet!!
was the clipping clutch the reason behind slower times with the boost?
Originally posted by ElKy:
sweet!!
I hope so, that and tires.On the way home is when i realized it was slipping badly.
Plus i tried locking my timing at 20 degrees, which really woke it up at low rpm. I had originally had base timing at 4 degrees (since i have no tuning) and i was running the factory timing curve. Thats how i ran it at the track. A couple days later I set the base at 20, and left the SPOUT out, which effectively locks it at 20 with no curve, and it spools quicker and is much more responsive. As soon as i get the new clutch in I will be back to the track, maybe some sticky tires first though.
Online Content
Do you have a vid of its run time?
I regret not knowing what you're talking about, but I suppose it means the car will go faster (duh). That car looks fast just standing still.
Moderated by  baco99, frenchblueC2_dup1
