muntus Offline OP
I'm trying to get my 3L to start, and I noticed that before I turn the key, the PATS light is NOT on like it should be. Of course, when I turn the key, it flashes like crazy and the starter doesn't engage. I can't tell if the fuel pump clicks on; I will check tomorrow. Battery terminals are clean, I think I have the grounds right, and I'm hoping I have everything plugged in.
Has anyone encountered a PATS light not flashing when the key is out and you are out of the car?
I will have to check all the fuses tomorrow as well(too dark now). Which fuses are PATS specific?
Black 1998.5 3L Oval Port Full HMS Transmission Lots of other stuff Ressurected 06/14/06
F12, F30, F34 (supplies the light), F25, F32 all go to the anti-theft/central locking module.
Steve
muntus Offline OP
Thanks, Steve. I didn't check any of the fuses, though. Last night before I went to sleep(hard to fall asleep, btw), I remembered that I had plugged together the huge square electrical connector behind the airbox, but that I didn't tighten the bolt that goes through it. This morning, after I did, PATS started blinking like it should, turned the key and it lit up for a coulple of seconds, fuel pump pressurized, light turned off, and I cranked the motor. What a relief.
Now if only my battery would hold a charge, then I might be able to start it.
