#1587883 06/10/06 11:10 PM
I purchased what looked like a pre-98 console (brand new) and it looked identical - with one exception, it doesn't have the extra storage area above the ash tray (and hence leaves a gap at the bottom of the instrument panel. Everything else is the same, mounting holes, shift boots, e-brake boot- anyone have any idea what this console is for?
#1587884 06/11/06 02:52 AM
A picture would help. Isn't there an additonal piece to the center console that bolts in to mount up flush with the radio bezel?
-Mike 98 Contour SVT Toreador Red #49 of 6535 Built on 3/25/97 WR Headers, Borla Cat-Back, Torsen T2 LSD, K&N Short Ram, S-AFC and Focus Shift Tower 85 Camaro 1969 358ci, 97 TA interior, 91 Z28 GrdEfx and Aero Wing 255rwhp
#1587885 06/13/06 07:15 PM
On The Pre-98's With Manual Trans There Is A Seperate Piece That Fills In The Large Gap Under Neath The Dash Toward The Firewall Area...As For The Gap Underneath The Radio Bezel I'm Not Sure...I'm Going Through the Same Thing And I Even Have A Pre-98 Radio Bezel To Go With It And Still It Looks As If I Have Wrong Or Missing Parts Due To The Gap. I Don't Yet Have The Seperate Piece That I Mentioned Above, so I Don't Know If That Part Eliminates The Radio Bezel Gap. Let Me Know If You Narrow This Down...
CSVT E0 3L 14.5 @ 94mph, Stock Intake, Stock Exhaust minus Resonator, CEL, And Broken Pass. Side CV...Untuned.
#1587886 06/13/06 07:36 PM
easy the pre98 mystique doesn't ahve the second din location as part of the centerconsole, it is part of the dash. The rest of the console is the same as a pre98 but again the pre 98 console has the second din location and will attach right to the radio
can post pictures later tonight
also above the second dim location there is a small thin insted that goes there to fill the space, again pictures can be posted later tonight
#1587887 06/13/06 08:09 PM
Yes Please Post Pics Brapple!! I Need To See These Pics To Get This Finished Up. I'm Tired Of All That Gap!!!!LOL!!!
#1587888 06/13/06 08:37 PM
if you look closely there is a thin plastic filler that goes between the second din location and the radio
this is everything that you need minus the shift boot
I am goign to go take more pictures now
#1587889 06/13/06 08:49 PM
How Does The Lower Console Attach To The Radio Bezel. I Know That There Are Two Holes Behind The Filler Piece...But There Is Nothing There To Attach The Screws To. Unless I Have The Pre-98 Bezel On...But the Mounting Holes Are Different For The Radio Bezel That I Have.????????
#1587890 06/13/06 08:53 PM
Nevermind...I think I Figured It Out By Looking At Your Pics. The Two Tabs That Stick Up On The Console "Slot" Into Two Holes Under The Dash And I Would Assume You Put Some Sort Of Screw Or Push Tab In Through The Back..?? Am I Correct?
#1587891 06/13/06 09:11 PM
yes the pre 98 has a radio tray and then the trim piece, it isn't one peice like the post 98:
the mystique center console and as you can see the second din location isn't part of the center console
now here is my 99 with the pre98 swap
#1587892 06/13/06 09:46 PM
Thanks BrApple...That Helps Me Out A Lot...Its Amazing How Confused This Got Me! I Have Three Pre-98 Centers And An SVT Center (Orig) But They Were All In Some Sort Of Disarray. This Will Help Me Get My Parts In Order...You Are A Gentleman And A Scholar.
