96 SE Duratec.
Waterpump exploded, I was weeks away from doing this along with several other tune ups . Engine did overheat for about 15 minutes badly, before I discovered it by hearing the fans in overdrive. This all happened hours before going on vacation.
Two weeks later...back from vacation.
Removed pump, backflushed and found most of the pieces. New pump installed with new thermostat.
Afer the pump was replaced the car started on the first turn.
Car has not been on the road yet.
I noticed that I am not getting heat inside the car.
The engine will also slowly overheat until the fan goes into overdrive at around the letter 'M' on the temp guage.
Questions:
I have only filled the engine with water. I did this just to check for leaks before refilling with 50/50 coolent.
Will this effect the cooling properties of the engine with hotter running engine?
I think the new thermostat is not working properly. I put my hand on the metal pipe running along the front of the rad to the water pump, and it does not seem to be hot at all. Is this because the thermostat does not open up? I get no heat in the car.
Also the manual states that the mounting bolts on the pump are torque to yield, and must be replaced. Nobody seems to talk about this here on the forum. Is this important?
When all this is done I will do a compression test to check for any other issues.
Thanks.
