#1587613 06/10/06 12:37 AM
N
ninja Offline OP
N
Installed fog lights on my 99 SE, also instaled headlight switch from a 95 SE (with foglight opption)... Is there anything else that I need to install to get them to work. Is there a different headlight relay or relay for foglights. I see a spot for daylight headlight relay that is empty, could fog lights go through that relay?
Thanks,
Ed
A day with out triple digits is like a day without sunshine
#1587614 06/10/06 01:02 AM
you need the fog lamp wiring under the dash which includes a relay
#1587615 06/10/06 02:28 AM
N
ninja Offline OP
N
After digging into the hundreds of posts, that is what I came out of it with. I will get harness and relay tomorrow at junk yard. It seems that the parking light mod will be easier to do with harness in hand.
Thanks,
Ed
#1587616 06/10/06 04:37 PM
There is also a plug that goes into the middle of the headlight switch. If I were toy I'd cut the plug from the junkyard and take that for reference.
I believe it was two wires I needed to install somewhere under the dash.
A Haynes manual is your best friend in this instance.
www.ChicagoCEG.com 2006 White Grand Prix
