#118301 05/04/02 02:04 AM
LBVSVT Offline OP
When UDP's first came out there was some talk about piggybacking the stock damper onto the UDP for harmonics reasons. I'm reviving this back ... can it be done to get the performance benefits of the lesser diameter UDP AND keep the safety inherent in the dampers?
Black 98.5 SVT w/ KKM intake, 73mm MAF, ASP pulley, Optimized stock Y-Pipe, 24mm hollow rear sway bar, Magnaflow resonator, Magnaflow mufflers, Roush springs, KYB struts
Administrator
Administrator
Been discussed before.
Answer: Apparently not, since the UDP changes the dynamics enough to cause the damper to not function in the right frequencies.
-Lance
Lance Kinley
CEG Webmaster
95SE, "Official CEG Beater"
Quaife, SVT parts, ST200 wheels, SS Y-pipe
I perceive you to be a stand-up, rational individual...
