Page 1 of 5 1 2 3 4 5
#118235 05/03/02 12:36 PM
F
F
laugh No loss in torque, very happy with this mod. It is NOTHING like pinning the secondaries, pinning the secondaries will not give you any clue as to what the car will ride with the seconday plates removed. I pinned my secondaries the week before and didn;t like the results. So just hearing from a number of guys who liked the removal of the plates I decided what the hell and I'm very glad I did!! wink The only opinion as to why the car drives different from pinning to removing I think has a lot to do with the IMRC. I believe whoever said the IMRC controls timimg is very accurate. With the secondaries pinned the timing didn't seem to be right on my svt but it seem just perfect (from a power feel standpoint) with the IMRC attach and the plates removed. Anyways I thought people might want to hear another testimony.
Eric
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's*
B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers.
Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
So you removed the rods as well, or just the butterflies?
Po-Jay
Ghetto Mods Galore!
Quaife-CenterForce Clutch-Butterflies Rmvd and Replaced again-Bassani Exhaust w/custom "Y"-Pipe-33% of Mystery Mod-Pro M 75MM MAF-BNoon Optimized SVT TB-B+M Short Throw-ES Front Engine Mount-Some Aesthetic Crap-
Blood,Sweat,Tears
Do I hear the Fat Lady singing?
98 E0 Silver Frost (Is there any other color?)
172HP 149TQ W/Bad A/F Mix
F
F
No just the butterflys, just in case I wanted to go back... :rolleyes:
Eric
Eric
Then you didn't do anything but pin them!
Think about it a minute...
The rods are still in causing turbulence and taking up surface area.
The point of this mod is to remove the turbulence and get more surface area.
BTW - It's the IMRC tripped (always open) that the PCM sees and this is why it ramps up timing early.
2000 SVT #674 - Check it out!
what kind of performance bennefits are you seeing? Upper or lower end? No torque loss?
1999 contour se sport- black mtx
-Duratec v6
-dual exhaust
-no resonator
-kkm induction system
-one loud stereo
-35% window tint
-18' Enkei CDR9's on Kumho Ecsta Supras.
-Audi A6 Sidemarkers
(Coming Soon, Very Soon.)
-SVT front and rear bumper.
2002 Passat V6 GLX 4Motion
F
F
No, It's not the same as pinning them. The IMRC reactes different pinning to removing AND there is less surface area (considerably less) without the butterflys than with. High end is very noticable, low is better but not as good as the high end.
Eric
It's all BS until I see dyno proven results for something like this...does anyone have REAL proven numbers?
Regards,
Craig J. Baldwin
99 SVT Contour - Silver - #49/2760
"To make a living is to get, to make a life is to give." - Winston Churchill
Explain to me why it's not the same?
When the secondary plates are attached to the rod and the secondaries are open. They are straight up. Therefore their frontal surface area is equal to just the rods, because the rods are larger in diameter.
The turbulence & surface area loss from the rod would be the same or very close. One could even argue that the much thinner plate being first helps split the air better (less turbulent) then hitting just the rod itself wink
You would gain a little area from removing the screws though.
By the way...
Are you running with a CEL?
DemonSVT,
I cant see how having the plates vertical in the airflow creates the same turbulance and obstruction as to not having the plates there and just the bar.
Im going to wait to do this mod until I can get a second 2000+ LIM and take the rods and plates out, but leave the spring mechanism in place for the IMRC cable to connect to. I will install the LIM and see how the car drives. If I like it and if my car tests stronger on the dyno and faster at the track, then I will keep it on.
Nikolas
1999 Mercury Cougar V6
KKM Intake,SVT TB, SVT Upper/Lower, 19lb injectors, Diablo Chip, MSDS Headers, Custom Exhaust, B&M Short Shifter, Progress Lowering Springs, 18" Axis TC's, OMP Strut Bar, AAM 24mm Rear Sway Bar, Koni Struts
15.09 @ 91.54(corrected, pre-SVT conversion, DiabloChip, and Injectors)
Yes this mod does work. I have 181.2hp @6600rpm.
I did lose some tourqe I thought but as long as I am up higher its great!
1998.5 T-RED SVT
18" Team Loco 142's W/ Dunlop Rubber
181.2hp@6900rpm/155tq@5000rpm
LOTS OF MODS OF EVERY KIND....
...Am I a guru yet??? No... not yet.
