Posts: 1,325 |
I know most have you have moved on - but do any of you remember if I loaned my spring compressors to you? I seem to recall maybe Eric had them at some point? I just want to know if I should bother tearing up my garage looking for them or not?
97 Contour SE MTX
04 Grand Caravan SXT
Posts: 2,353 |
Not it...
1999 Blk/Tan CSVT #654 - SOLD
2003 Suzuki SV650s
Posts: 1,325 |
I know I had them in my trunk for a while for Eric, but I don't actually remember if I ever met up with him to give them to him. I could've just lost them when I moved but they are kind of big and heavy to just dissapear ![](/ubbthreads/images/graemlins/crazy.gif) Kragen has loaners don't they?
97 Contour SE MTX
Posts: 2,353 |
2003 Suzuki SV650s
Posts: 2,469 |
I dont i dont have them and never used them. When me and eric did my springs we borrowed a set from one of the autoparts stores, but couldnt/didnt need to use them cause they were to big and got in the way, It was actualy easer without them. I have no idea if eric has them, but i know he did his springs before mine, so i dont know why he would have them. But you never know with eric didnt he have your pulley puller for like 6 years
Posts: 1,325 |
How'd you get the springs off without a compressor? I can see it now, Eric says "Hey Harley come hold this spring while I remove this bolt"
97 Contour SE MTX
Posts: 1,325 |
Found them, they were on a shelf behind a box of extra tile
97 Contour SE MTX
Posts: 2,469 |
Originally posted by ScottK: How'd you get the springs off without a compressor? I can see it now, Eric says "Hey Harley come hold this spring while I remove this bolt"
You pull the strut and spring together(obviously) you just have to drop the hup which is a pita. then lay it on the ground and unscrew the nut holding the "cap" that holds the spring. Yea it goes "boing" but you just face it towards a wall. Also remeber i put in h&r's so putting everything back together was cake.
