Posts: 2,978 |
So I was having problems with it stalling. Today the check engine light came on, the low gas light came on and the high beam light started flashing... all within about 2 miles. I parked it at a ford dealership about half a mile away from the CEL. I walked in, told the man I had a CEL and the car was being stupid... handed him my keys and walked 10 miles home. I <3 this car more every day.
Posts: 216 |
10 miles? What dealership did you leave it at? Sure wasn't chapman.
2006 Fusion SEL (Fully Loaded)
Fusion Boards
1992 Thunderbird 3.8 V6
Former 1998 Contour SE Sport owner
Posts: 6,910 |
sounds like a bad battery to me
- 95 Mystique LS - Zetec/5spd
Posts: 317 |
sounds like you need a hug...
Originally posted by LUCA: Yep.
You can be Phil too if you'd like.
Posts: 2,978 |
I picked it up today.
171 dollars to have them give me a code... unhook the light in my trunk which was draining my battery... and not look at my brakes.
My car is now on jackstands sans wheels in my garage and isn't moving until I figure out how to fix the brakes. The drivers side is apart right now and I am trying to figure out how it works. I hate this car so much. Once it gets fixed I will seriously consider trading it for a civic or something that will not break, or will be cheap/easy to fix when it does. This is [censored]. Thanks.
Posts: 3,788 |
What's wrong with your brakes?
Posts: 2,978 |
The brakes are squealing really bad at light - mediumlight braking. Right now the problem i have is that the caliper is moving around like crazy even with the whole thing bolted up. It moves quite a bit and i might get a video of it later. Oh, and I found a new way to bling the engine bay.
Posts: 4,155 |
Hey guy, don't sweat it. When your car starts stalling 500 miles from home.. yeah  The world is a much bigger place when you have to walk it
Posts: 317 |
Originally posted by Banned At Heart: The brakes are squealing really bad at light - mediumlight braking. Right now the problem i have is that the caliper is moving around like crazy even with the whole thing bolted up. It moves quite a bit and i might get a video of it later. Oh, and I found a new way to bling the engine bay.
There are only four attachment points for the entire front brake...two bracket bolts and two slide pin bolts. One of those might be broken or stripped which might be causing your problem.
Posts: 7,431 |
What's with the trunk light draining people's batteries these days? A friend of mine had the exact same problem with his Acura TL (car needed to be jumped if left alone for a day or two ... took many dealership trips for them to figure out the problem!)
