Posts: 18 |
Hi,
Has anoyone here been successful in removing a bank 1 precat from a 96 V6 contour? Do you need to remove the radiator hose(s)?
Posts: 1,788 |
According to the service procedure, removal of any radiator lines/hoses is not required.
Just so it is certain that we're discussing the same thing, Bank 1 is the firewall side, AKA the RIHGT HAND (RH) side of the engine.
Exhaust Manifold RH (211860)
Removal
1. Remove the generator and the generator mounting bracket.For additional information, refer to �«Section 414-02�».
2. Remove the dual converter Y-pipe.For additional information, refer to �«Section 309-00�».
3. Remove the right-hand halfshaft support bearing retainer bracket.For additional information, refer to �«Section 205-04�».
4. Remove the right-hand heated oxygen sensor (HO2S).For additional information, refer to �«Section 303-14B�».
5. Raise and support the vehicle.For additional information, refer to �«Section 100-02�».
�µ 6. Loosen the exhaust gas recirculation (EGR) valve and remove the nut to the exhaust manifold. l Loosen the EGR valve. l Remove the nut.
�µ 7. Note: Remove the nuts in the sequence shown.
Note: Remove and discard the gasket. Remove the right-hand exhaust manifold.
Installation
�µ 1. Note: Use a new exhaust manifold gasket.
Note: Tighten the nuts in the sequence shown. To install, reverse the removal procedure.
�µ Refer to corresponding illustration.
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
Posts: 18 |
Thanks for your reply. My bad though. I was referring to the precat in the radiator side. this should be Bank 2 then...
Posts: 1,788 |
Originally posted by vdiaz: Thanks for your reply. My bad though. I was referring to the precat in the radiator side. this should be Bank 2 then...
Well, that one's even easier:
Exhaust Manifold LH (211870)
Removal
1. Remove the left-hand heated oxygen (HO2S) sensor. For additional information, refer to �«Section 303-14B�».
2. Remove the exhaust crossover tube. For additional information, refer to �«Section 309-00�».
�µ 3. Remove the nuts and remove the left-hand exhaust manifold and gasket in the sequence shown. l Remove and discard the gasket.
Installation
Note: Tighten in the sequence shown. To install, reverse the removal procedure.
94 SHO ATX - 190K
