Posts: 785 |
how long is to change the alternator on a SVT ?
1998.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 -
RU-3530/CTA Intake Pipe
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
SPEC Stage one/Spec Alum. Flywheel
HERE
Posts: 7,100 |
first time, on your own.. with NO PROBLEMS? a couple of hours.. maybe 3 or 4?
lol
follow the how to.
'99 CSVT - Silver #222/276
Posts: 785 |
ok, cause my battery is not charging anymore since a few day, the same day, my starter die... i easily changed the starter.. but im afraid of the alternator
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
HERE
Posts: 7,100 |
check your mega fuse, and wiring between the alternator and battery, alternator and ground, and battery and ground.
check battery voltage too engine off, headlights on for 60 seconds across terminals 12 volts or more
engine running 13.5-14.3 volts
Posts: 785 |
which fuse should i look at ? where is it located
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
HERE
Posts: 7,100 |
Read the alternator removal how-to in the Duratec maintenance FAQ in its entireity... you'll need to be familiar with the procedure anyway, and it will show you the location of the fuse.
Posts: 24 |
I'm not the brightest bulb on the tree, but I'm also not the dimmest.
It took me about 10 hours to do it the first time. I could probably do it in 5 this time. Follow the how-to. The book says to take off the exhaust ypipe, which would have made getting at the bolts easier than between the block and the firewall, but my fasteners were rusted to hell. So removal of y-pipe wasn't going to happen. Get at the top bolt from the top of the engine - it's easier, just make sure you have lots of extensions.
The book also recommends removing the drive-axle. I did this and found that I valued the extra space.
Good luck - it's a pain in the arse to remove.
Like EVERYTHING on this engine.
Horsepower is more expensive than crack.
Posts: 1,049 |
just make sure you have a new battery or a fully charged battery. im on my 4th battery and alternator. the parts stores gave me the wrong battery 3 times. also for some reason in my car if i pull the fuse under the hood that is for the foglight my battery wont charge. i had a problem with my foglights not staying off so i pulled the fuse for the fog lights under the hood. a few minutes later my battery was dead. i put the fuse back on gave it a jump and back to normal i also had to pull the fuse whenever i parked. the foglight problem went away on its own but in return my dash lighst tend to go out on hard bumps i think i need a new headlightlight knob\swith. unless it has somehtign to do with the foglight mod. i thik i might check it today.
Posts: 2,007 |
Originally posted by cvkillacontour98: also for some reason in my car if i pull the fuse under the hood that is for the foglight my battery wont charge.
Yep, i don't know if its just 98s or all the way from 95-00, but i found the same thing. One of the wires from the 3 wire plug that goes to the regulator is fed off of the fog lamp circuit, but the owners manual makes no mention of this...its only in the service CD.
1998 Mystique LS:
-2.5 Duratec ATX
-Vibrant White
=Pics=
=Info=
Posts: 785 |
wow guy you just safe my life... i check under the wood and i didnt have #5 fuse... so i put one and no more battery light
but i wonder why there is no more fuse there, just remember to have pulled out fuse tu see if they were good the first night my starter wasnt working.
i so put a new one and the car is great now !! thx David
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
HERE
