#15542 05/14/02 11:06 PM
Danny Offline OP
Okay, so I just got my supply of Amsoil. One question though... The engin flush says to empty one pint out of the engine (or just take the filter off), put in one pint of the flush and run the engine at a fast idle for 15 - 20 minutes. What is considered a fast idle?
One other thing. It recommends to use a filter while you do the flush. So I'll throw on a Fram for the 15 min flush, then put on my Amsoil filter for the next 6 months. What size filter do I need for the SVT?
2000 SVT
Black & Blue
#205 of 2150
Kenwood Head Unit
2001 SR5 4 Runner 4x4
#15543 05/15/02 01:21 AM
H
H
Don't worry about removing the one pint, I put 6.5 qts of Amsoil in the Contour every oil change, Ford Engineers recommend it.
Also use your old filter, just add the pint, follow the instructions, then do the oil change.
I run 6.5 qts of 0W-30 Series 2000 Amsoil for 20k, oil changes at 5k, 10k, 15k.
I have 102k miles, no engines problems. 28 mpg mixed driving.
98 T-Red Contour LX V6 Mtx 106k miles
9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
#15544 05/15/02 01:25 AM
~1500 RPM?
It is a PH2.
T.
'97 Contour SE 2.5 MTX
#15545 05/15/02 04:08 AM
Originally posted by sheltot:
It is a PH2.
T.
Only for those of you that absolutely HATE your car.
For the rest of you: Use atleast the FL-820S
2000 SVT #674 - Check it out!
#15546 05/15/02 05:39 AM
buy the ams oil filter.
"careful man, there's a beverage here."
e-mail: boseraq@hotmail.com
aol IM: madhat1412
#15547 05/18/02 05:10 AM
wink
Howard
1998 Silverfrost SVT #1612
June mods:
17" ADR RS Limited Limix Wheels
with 215/45/17 Yokohama AVS Sports
