Hey for everyone with the typical saggy bosal problem, I've figured out a cheap fix.
I've tried shorter rubber hangers and they look good for a bit until they strech and make their initial hanger tear in. They they look almost as bad as before, and 6 $ a hanger for 3-4 weeks of looking good isnt worth it..
Soooo...
http://cgi.ebay.com/100-Pcs-14-Black-Cable-Wire-Ties-120-Lbs-Zip-%20Fasten_W0QQitemZ7625280293QQihZ017QQcategoryZ57007QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
120lb cable zip ties. they are 14" long perfect length.
So you can either use them in conjuction with an old rubber hanger and pretty much use a few of them as a hanger OR you can get a new rubber hanger and wrap these around it so it can't stretch it down.
These are extremely strong, none have broken yet in months of use. I have them pretty much taking the place of the rubber hanger pulling up the system higher than the rubber hanger could when it's as tight as possible. But I left the hanger there in case it ever dropped for extra protection.
