Well, I'm sure as hell leaking something. After sitting 8 hours, the car leaves two wet spots, maybe 6 x 4" or less for each. They're on opposite sides of the car, about 8-12" in from the wheels; the driver's side spot is about even with the wheel's contact patch, the passenger side is maybe half a foot behind it. The fluid is dark, but not dark enough to be oil. I checked all fluids; everything is ok, except for power steering, which is a bit low. The car has no symptoms, other than some slight noise in the steering, which the car has always had, and the clutch pedal has felt slightly odd (stiffer, a tiny bit less travel). This could be in my head (once I know something's wrong, I'll just start looking for things, as I'm sure we all do), but I thought it felt off before I noticed the wet spots.
So, ideas? I guess the rack could be going, or worst-case is I guess a crack in the trans case (don't our trannies have power steering fluid, or am I miss-remembering?). I'm taking it to a shop tomorrow, since I have no way get the car up and poke around, but ideas and direction would be quite helpful. Thanks!
