#117929 04/28/02 03:41 AM
GSVT Offline OP
Good or bad idea? Tell me what you think, or have experienced. Is it a waste because it is only restricted then by the trottle body? should I get a new tb in addition.
99 Green Contour SVT (still gotta find out the number) 17'' Millie Miglia Cello, 225/45/zr17 Toyo Proxes FZ4's, True Rev, Borla, Amber removed, BAT Struts Soon: PIAA 510 fog lamps
#117930 04/28/02 08:01 PM
H
H
i think most will tell u its overkill. 75 seems to be the most common.
AIM:omegazodiac
95 gl
99 contour svt #1750/2760
built 4/6/99
black/tan
plates, not personalized (###-REV)
amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
#117931 04/28/02 09:06 PM
hmmm....i wonder what the dyno would say? it does seem rather large for the car....and i am assuming it is overkill, but i wonder how much overkill, or if overkill at all?
sorry man - i can't give you a definate answer..
#117932 04/29/02 12:24 AM
Some have dyno'ed the Pro-M 75 MM and 80 MM with the same gains (no difference). I got an 80 MM off a Cobra and butt dyno proved big gains(probably the same as the Pro-M 75 MM). I got it for $50 on E-Bay and was well worth the $$. The only problem was fitting the MAF adapter to it. Only took some careful drilling and EUREKA!
justSVT My Tour is a cross breed.
