Posts: 27 |
Butterflies on intake werent opening up when they were supposed to i was clueless as to what the problem was but i traced the wireing from the imrc to a o2 sensor and i simply unpluged it and car ran great..I had no power what so ever..Now the beast is up and going again
Posts: 5,345 |
Originally posted by fordman302: .. i traced the wireing from the imrc to a o2 sensor ...
What exactly did you do now? A detailed step by step procedure would help. Thanks.
1996 V6 ATX 96K miles
Posts: 770 |
You caused the limp mode to kick in. It will run a bit rich so you better find out what's really wrong.
Posts: 7,100 |
unplugging the O2 sensor lets the PCM NOT see what you are doing right then.. it can't make its decisions based on DATA so it defaults to a base set of tables, which is PIG RICH..
find the REAL problem.
'99 CSVT - Silver #222/276
Posts: 27 |
Well yes i know i have to fix the problem im purchaseing all new o2 sensors
Posts: 1,788 |
Originally posted by fordman302: Well yes i know i have to fix the problem im purchaseing all new o2 sensors
That will likely be a waste of money, or at least, an unnecessary expense.
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
Posts: 27 |
Well i just replaced the o2 sensor and reset the pcm and the check engine light hasnt come back on and car is runing alot better a/f ratio is right again.Why would it be a waste of money?
Posts: 1,049 |
just do this buy 2 new o2 sensors and get mil eliminators for the ones after the pre cats. it wont give a cel when the pre cats go bad but you will know when the rubber tubes that go to the dpfe melt and melt the dpfe with it.
Posts: 27 |
Dpfe? whats that?..Yes im getting the mil elminators..
Posts: 5,345 |
Originally posted by fordman302: Well i just replaced the o2 sensor and reset the pcm and the check engine light hasnt come back on and car is runing alot better a/f ratio is right again.Why would it be a waste of money?
The PCM takes time to run through the OBD II cycle. It won't show a CEL until it goes through the whole cycle. You did not have enough info to determine that it was the O2 sensors which was causing the fault. Definitely not the lower Bank 1 and lower Bank 2 sensor (which is why Projectsho89 said you would be wasting your money).
Incidentally, why did you replace the lower O2 sensors when you planned on installing mileliminators?
Edit. Differential Pressure Feedback EGR.
Originally posted by chongo: Did someone call me out.......LOL
here you go.
