Sorry, it is actually a relay in the roof console. You should also test if the switch is working.
From 1996 Ford CD Manual
Monroof Relay
Removal and Installation
1. Note: When the battery is disconnected or reconnected, some abnormal driving symptoms may occur while the powertrain control module (PCM) relearns its strategy. The vehicle may need to be driven 18 km (10 miles) or more to relearn the strategy.
Disconnect battery ground cable.
2. Remove roof console.
3. Disconnect wiring harness to sliding roof panel relay.
4. Release clip and slide sliding roof panel relay off from mounting bracket. Remove sliding roof panel relay.
5. To install, reverse Removal procedure.
Console, Roof
1. Note: When the battery has been disconnected or reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) relearns its adaptive strategy. The vehicle may need to be driven 18 km (10 miles) or more to relearn the strategy.
Disconnectbattery ground cable.
2. Remove dome/map interior lamp.
3. Carefully pry sliding roof panel switch out of roof console.
4. Disconnect and remove sliding roof panel switch.
5. Remove two screws retaining roof console to roof.
6. Slide roof console to rear of vehicle to disengage roof console retaining clips. Remove roof console.
7. To install, reverse Removal procedure.
