Posts: 44 |
O.k my clutch is officialy slipping big time and was wondering if anyone could recomend a good clutch. Ford wants to charge me $1,300.00 for one including labor and I think $20 for some Lubercate for may @$$  . Please Help!
2000 Silver Frost SVT #77 of #2150 KKM, No Resinator, Custom Heat Sheild, Gutted Out Pre-Cats, Ultra Street Underdrive Pulley, Polished Aluminum Intake Pipe, Ford Racing 9mm Plug Wires, Modified SVT Sail Pannels, Audi A6 side markers, Blue SVT Stickers, Silver Dash Kit, Clear Corners and Blue calipers
Posts: 154 |
Yep, that sounds about right as Ford quotes it as over a 9 hour job. You are mostly paying for the labor. I just had mine done, and I got it cheap at $900 for everything. But I didn't have Ford do it.
95 mystique LS, High Output Cougar S (SVT) 2.5L engine & MTX75
Posts: 1,812 |
you have a 2000 and your clutch is slipping? how many miles do you have on the thing?
2000 Silver SVT #1602 Check it out in the registry! Mi Coche
Posts: 44 |
I only have 33K any every one i let test drive it says the same thing. I'm goning to have a friend of mine look to see if it is some thing else. I must be hard on the clutch.
Posts: 1,355 |
The clutch isn't coverd under the drivetrain warrenty?!?!?! That's cheap!!
Well, $1,300 for a STOCK clutch replacement is stupid!
Get a good aftermarket clutch for around $400 and pay around $600 for labour. Yeah, your still looking at $1000 for it, but you'll have the assurance that this won'thappen again!! (at least not for a VERY long time!)
A word of advice though for choosing a clutch, don't go for a clutch that is too much for you. meaning, don't buy a "super heavy duty" clutch as daily driving will be hard, not to mention the clatter you will hear from your clutch. UR Stage 1+ or the Clutchmaster Stage 3's are prime examples of this.
RAM does a good heavy duty clutch (powergrip), Sach, UR stage 1, Clutchmaster stage 1 or 2, Grizzly OEM clutch.
Remeber this - the LESS pucks on the disc, the harder it will be to drive (daily driver).
Hope that helps.
Simon W. Las Vegas. 96 SE V6 MTX Tereador Red (1st Blown Engine, better be the last!) 1999 SVT Engine SVT Exhaust w/custom DTM Tips and optimized Y-pipe and no Res (thanks to Po-Jay!). LSD Quaife(thanks to Terry!), SCA CAI w/KKM, Grizzly clutch, FMS 9mm wires, Airknights custom short shifter.
"You can only get more rice at one time by ordering Chinese" - Davo7SVT "it's only nuts and bolts" - Terry Haines "Drive it like you stole it" - Me!
