#1581929 05/31/06 09:47 PM
KVX Offline OP
Was wondering if anyone else has oil blowing back through the crankcase breather tube into the air filter box? Also what has helped to fix it.
#1581930 05/31/06 10:38 PM
Check your PCV valve.
#1581931 06/01/06 12:31 AM
would that fix that then?
G/f's black 99se sport 5 speed 2 1/2 test pipe-custom cat back 3 single tip cai with kn3530 safc optimized tb 8mm plug wires spec stage 1 clutch svt front bumper
#1581932 06/01/06 12:35 AM
Probably need to change it.
#1581933 06/01/06 02:07 AM
KVX Offline OP
Already have done that multiple times. Still does the oil blowback. Even had to replace the breather filter and air filter multiple times, because they get destroyed by this oil coming in.
#1581934 06/01/06 02:21 AM
2
The plumbing from the PCV valve to the engine in good shape? It needs to draw a vacuum on it otherwise the blowby gasses will go out the inlet. Any other oil leaks? Big ones like leaky cam covers will keep it from pulling the gasses out to the PCV valve. In a worse case if the piston rings are almost shot there will be too much blowby and it will blow lots of oil out too.
#1581935 06/03/06 12:08 AM
KVX Offline OP
There are really no other leaks. Lose at the worst a quart into the air box between oil changes.
