Posts: 6 |
I have a 99 Contour SE Sport with worn out front control arm bushings. I've searched high and low on the internet (including this website) and nobody sells just the bushings - you have to buy the whole control arm. The only place I've found that sells the control arms is BAT Inc. I called them and they're out of stock and don't expect more to come in for several months. Can anybody help me locate a vendor who sells these control arms? Thanks in advance!
Posts: 6 |
BTW, my control arms have the vertical two-bolt bushings.
Posts: 6,910 |
try checking the parts source page on the main page ...
also go to teamfordparts.com, there are like $60 a arm, just replace the arm and you will be good to go
- 95 Mystique LS - Zetec/5spd
Posts: 6 |
Cool - Thanks! I ordered a left and a right control arm from teamfordparts.com for $104 including shipping.
Posts: 8,445 |
lucky...i had to pay $105 each, for my LCAs.
NY State Trooper: So what makes your car so special to have SVT all over it?
Me: Er...It was made by Fords SPECIAL Vehicle Team?
Posts: 7,117 |
Originally posted by ElKy: lucky...i had to pay $105 each, for my LCAs.
Two bolts RULE!!
Posts: 1,325 |
Where did you get them that cheap - that's like $40 better than I found?
97 Contour SE MTX
04 Grand Caravan SXT
Posts: 4,140 |
Originally posted by TourDeForce: Two bolts RULE!!
Except that the design sucks - a lot.
Posts: 4,140 |
Originally posted by ScottK: Originally posted by ElKy: lucky...i had to pay $105 each, for my LCAs.
There's a CEGer that has a good price. Bill is close to that, too.
Posts: 291 |
The 2 bolt arms, although easier to remove and install are a worse design than the 4 bolt arms. Ford even went back to the 4 bolt arms with later Cougar production because of this.
The 2 bolt design puts undue stress on the bushings and causes them to fail prematurely. When they do go, the A arms flop around-not a good situation.
If you have a choice go with the 4 bolts. Eventually, I'll have replacement bushings for them.
Redcoat Raceworks. Performance parts and custom fabricating for Contours, Mystiques and Cougars. Specializing in chassis and suspension parts. Custom end links, control arms, strut tower bars, engine torque braces, etc.
