#117801 04/25/02 01:22 PM
Are all duratec (SVT and non-SVT) y-pipes the same? I want to get a y-pipe to modify and want
to know about this before I start calling recycle centers ("junk yards").
2000 T-Red SVT, #562/2150
K&N w/heatshield
#117802 04/25/02 02:47 PM
Yes they are.
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
#117803 04/25/02 06:47 PM
dwh Offline
The pipes are the same, but the flanges are different in the later years... Three hole vs the 2 hole flanges on my 95. Also more o-2 sensor points on the later years. Mine has none.
95 mystique LS, High Output Cougar S (SVT) 2.5L engine & MTX75
#117804 04/26/02 05:35 AM
Originally posted by L8 Apexing Aussie:
Yes they are.
No they're not. As dwh said, 2 bolt for older cats, 3 bolts for newer. Since it's once piece, technically, different. wink
I can't remember what year the flanges changed... confused
- Pete - 00 SVT SF/MB - 1522/2150 - DOB 1/12/00
92% says your group-NOT HOT
85% says your either wrong or BLIND
Blackhawk Down did NOT suck
you know who you are.....
#117805 04/26/02 12:37 PM
Where doy ou get the idea the later ones have more O2 sensors. All contiques have 4 O2 sensors, one before each pre cat and one after!
-Andy
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
#117806 04/26/02 12:44 PM
Master P
Master P
-Andy
Even 95's?
#117807 04/26/02 01:00 PM
95s are OBD-1 and have only 2 O2 sensors total. Also my 95 ATX has 3 bolt flange. Not sure when/why the change to 2 bolt came in?
Scott
#117808 04/26/02 01:22 PM
dwh Offline
maybe twowheelin has a special animal, but I believe the flange change was in late 96 or early 97. For all you obdII people, the obdI cars only have o-2 sensors in the precats. Just 2, one on each precat. The obdII cars have four, 2 on the pre cats, and two after. Ford changes some of the wierdest things sometimes for reasons known only to them. For example, when I bought a set of gutted pre-cats out of a newer car to use on mine, I couldn't because the egr mounting hole was different on the newer pre-cats.
#117809 04/26/02 03:55 PM
So then 95's don't have aftermarket headers either??
-Andy
Andy Watson
Graci!
#117810 04/26/02 04:00 PM
dwh Offline
the 95's can use the msds headers and y pipe. you just have to be creative about plugging the extra holes.
