Hello On the weekend i changed the coolant and thermastat on our 98 zetec.Today the A/c stopped blowing cold air . I was just wondering if it could be related ? or is is just a seperate problem .Thanks
Originally posted by jakerboy: Hello On the weekend i changed the coolant and thermastat on our 98 zetec.Today the A/c stopped blowing cold air . I was just wondering if it could be related ? or is is just a seperate problem .Thanks
Most probably separate problem. Unless you accidentally bumped a switch loose. If it is only blowing air then check if there is enough refrigerant. Autozone or Advance sells the recharge kits with gauge for about $25.
1996 V6 ATX 96K miles
