i was out the other day testing my RPMS and i noticed that my engine runs very cold sometimes not even touching the NORMAL is this normal? the way ive been revving up my engine i dont think it should be below normal
Originally posted by zetecpower: i was out the other day testing my RPMS and i noticed that my engine runs very cold sometimes not even touching the NORMAL is this normal? the way ive been revving up my engine i dont think it should be below normal
i have the same problem and i think its actually the gauge sending unit. the zetec's have 2 temp sensors, one for them is for the PCM and the other is for the gauge. of course the lower one (hardest to get to) is the one for the gauge which is why i havent replaced mine yet
97 contour gl mtx
front & rear upper strut tower braces
19mm bat sway bar
Koni struts w/GC knockoffs
last time i changes my thermo was about a month ago that was after i had overheating problem. i drained my whole cooling system added new thermo with lower temp resistance and added water wetter and now my engine runs cool maybe its accurate bc sometimes it climbs up to R/M but ussually its cool up to N in NORMAL. what a dilema
mine doesnt even get to the white part of the gauge. i need to hook up a scan tool and see what the pcm is reading for a temp but i think mine is actually the sending unit. that or its a wiring problem cause i did see it work once or twice a few weeks ago.
97 contour gl mtx
19mm bat sway bar
