Page 3 of 3 1 2 3
#117670 04/27/02 01:30 AM
anyone know where i can find info about that dynabatt battery?? so far no good searching
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
#117671 04/27/02 01:41 AM
#117672 04/27/02 01:54 AM
Why Is the engine compartment White?
Kick Ass don't Kiss It
#117673 04/27/02 05:50 AM
Originally posted by L8 Apexing Aussie:
His oil separator is a home-made. I can tell. It's a 2" (maybe 3")PVC pipe with two PVC encaps glued on. Then two brass screw-in barbs and finally a brass screw-in drain cock in the bottom. Paint it silver an viola!
Cost you like $15 for all the parts from Home Depot. How close was I Greg?
Cost under $10 easily & I have 9.5' of PVC piping left over too... laugh Home Depot was correct wink
Oil Seperator - the Celica link.
The only thing I changed was using brass 90 degree fittings & a radiator drain cock (I have drawers full of those parts! Perks from work laugh )
I also valley'd the return hose for added measure.
You can make one using this How-to. Routing the hoses is a piece of cake.
Stock headlights with 4x 9005 Xenon bulbs. Reflectors removed. Polished the lenses and added LED's for turn signals.
Been having problems with the LED's though frown Added sidemarker at the same time. Circuit may be overloaded???
Engine compartment is white because picture was taken with a flash (in a closed garage)
2000 SVT #674 - Check it out!
#117674 04/27/02 06:14 AM
Sweet pics. That is one big ass filter. eek
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
#117675 04/28/02 07:45 AM
Really like the idea of the oil separator. Just so I'm clear, the hose from the PCV valve goes to the side of the oil separator. The top outlet goes to the upper manifold? Am I correct?
How often do you think you'll be draining the oil from the separator??
Thanks for your help!
Paul.
5 Dr, 2.5 V6 Ghia X, 1999
Modifications:-
Inventor of the inductive Secondary monitor
Chrome grill
JR cone air filter
Black Diamond cross-drilled & grooved discs with Predator pads,
ST200 throttle body, upper and lower extrude-honed intake manifolds
Scorpion s/steel exhaust
Current Project.. Building a ST200 powered MKI
paullorman@btopenworld.com
#117676 04/29/02 03:56 AM
Originally posted by Paul from the UK:
1. The hose from the PCV valve goes to the side of the oil separator. The top outlet goes to the upper manifold? Am I correct?
2. How often do you think you'll be draining the oil from the separator??
1. Yes. I mounted it as low as possible (and still fit with the cap on - drill with the cap installed laugh )
2. With how bad the intakes looked. Once a week. wink However seeing as I never noticed any oil level loses on the dipstick, probably check it once a month until I get a feel for it.
The main reason I used a easy open drain cock with a long spout was for easy drainage.
Therefore I could just pop a hose on, twist it and be done...
#117677 04/29/02 04:12 AM
E
E
Originally posted by DemonSVT:
Been having problems with the LED's though :(Added sidemarker at the same time. Circuit may be overloaded???
I think that may just be the LED turn signal bulbs. I tried a set of the rears and it made them flash like a bulb was out, like there was not enough resistance. I have heard this from others too.
Looks good, can't wait to see it at the track this summer. I know I won't stand a chance, but maybe if Sam gets his sh*t running right, you can break that tie. wink
2000 SVT Contour - Silver # 1675/2150
svt1675@comcast.net
This Shine brought to you by the letter "Z" for Zaino
#117678 04/29/02 09:27 AM
ok... 3 quick questions...
Will the oil seperator work on the cougars?
Why is this thing sucha good idea?
Are LED bulbs brighter?
THANKS,
BEN
#117679 04/29/02 11:25 AM
Originally posted by Dan Nixon:
Man I should make a bundle. Anyone intereted?
Hey, go for it. I have little time to make stuff like that & would probably cough up $30 or so if you included install instux. smile
Dan, I may make a few this week. Email me if you are genuinely interested. The same goes for anyone else. The price I stated would include Priority Mail shipping to you.
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
Page 3 of 3 1 2 3
