I will show you step by step on how you would change your gauge to any color you want with ease.
Project in PROGRESS
STEP ONE
STEP TWO
open your guages
around your gauge you will see 5 snap and locks open them and you have...
STEP THREE
Unscrew all the screws to take your clusters out( about 5-6 of them)
STEP FOUR
carefully remove the needle and set it aside. Remove the MPH cluster from the assembly. Then remove plastic film thats glued to the cluster. ( use knife or screwdriver)
STEP FIVE
Plastic film is coated with some special colored film to give your clusters color, ussually green and red. Use sand paper and sand down any numbers you want to change the color. Send only untill the Number becomes white and no green is visible.
FRONT
BACK
STEP SIX
Use any desired color LED bulb instead of the original. Im going to use BLUE and RED MPH=BLUE KPH=RED. I would prefer to use HIGH INTENSITY LED"S WITH 180 degree viewing angle for better looks.
STEP SEVEN
Carefully assemble your gauges and plug all the LED'S plug it in your CAR and your ready to go.
COMMENTS FEEDBACKS AND PICTURES OF YOUR PROJECTS PLEASE
