Posts: 60 |
Finally brought the 89 to the track. I dont know how to feel at this point, I ran slower than my best ET when it was all motor, but trapped higher. Nitto Drag radials blow!
Best Run
60': 2.331 300: 5.974 1/8: 8.682 mph: 91.24 1000: 10.974 1/4: 12.821 MPH: 120.12
guess its time for Slicks!
00 SVT #985
Silver Frost
89 Mustang GT TT
-410.6hp/460.7trq (couldnt pull past 5k-lean)
12.77 @106 Before turbos, 12.82 @120.12 With them
-95 Contour GL, 140K FREE!
-WPI FSAE 05'-06', build a race car, get school credit
Posts: 201 |
Wow man, that's definitely a low to mid 12 second run if you don't spin through the first 60'!! A 2.3xx 60' time is absolutely horrible, so if you get good slicks and a nicely prepped track and produce a 1.9-2.0 60' time you'd be golden.
Posts: 7,392 |
Originally posted by dredwingz03: Wow man, that's definitely a low to mid 12 second run if you don't spin through the first 60'!! A 2.3xx 60' time is absolutely horrible, so if you get good slicks and a nicely prepped track and produce a 1.9-2.0 60' time you'd be golden.
120 mph traps will put him well into the 11's.
.....______
___|______\_____
|/-\_________/-\_|
.\_/...............\_/
Posts: 201 |
Yea 120mph traps do get you into the 11s, but it's also proven that crappy 60' times result in higher traps but obviously lower ETs. I would say high elevens low twelves since he can't find traction.
Posts: 7,392 |
Originally posted by dredwingz03: Yea 120mph traps do get you into the 11s, but it's also proven that crappy 60' times result in higher traps but obviously lower ETs. I would say high elevens low twelves since he can't find traction.
you're going to have to explain to me how having less traction = higher traps.
.....______
___|______\_____
|/-\_________/-\_|
Posts: 60 |
this was done with no tuning yet either. it should be deep in the 11's with tuning and slicks.
00 SVT #985
Silver Frost
89 Mustang GT TT
Captain Impound Boy
Captain Impound Boy
Posts: 8,281 |
I ran a 15.4 @113
Posts: 7,392 |
Originally posted by turbo_fox: this was done with no tuning yet either. it should be deep in the 11's with tuning and slicks.
indeed! aside from the hairdryers, what else is done to the car?
.....______
___|______\_____
|/-\_________/-\_|
Posts: 201 |
Originally posted by MxRacer: Originally posted by dredwingz03: Yea 120mph traps do get you into the 11s, but it's also proven that crappy 60' times result in higher traps but obviously lower ETs. I would say high elevens low twelves since he can't find traction.
I know I didn't believe it either because it's not really intuitive, but cars usually trap slightly higher if they have slightly worse 60' times. I did a quick search in google for "higher trap lower 60'" and low and behold a mustang forum link came up. Reading through it most people acknowledge this fact.
sleeper05 on that forum posts
"anyway, the best way to describe why better 60' equates to better ET but LOWER mph would be along these lines: getting traction off the line means a harder launch and better 60'. in the same sense that a good launch gets you to 60' down the track in less time, it would also get you to 1320ft down the track in less time than a bad launch (in theory). however, since you got there quicker, your car had less time to accelerate up to its maximum potential speed (trap speed). because it was accelerating for less time while physically within 1/4mi, it did not have enough chance to get up to a higher speed vs. a run with a good launch, BUT it got to the end sooner. this results in lower ET, as well as a lower trap speed."
So this guy with a badass fox body mustang with turbos is making insane power which still gets him very respectable ETs even when he has terrible 60' times with no tune. HP determines ET, and lower 60' usually result in slightly higher traps. So when he tunes and runs elevens, I bet he traps 116-118 with a time of 11.7-11.8sec.
Posts: 7,392 |
Originally posted by dredwingz03: "anyway, the best way to describe why better 60' equates to better ET but LOWER mph would be along these lines: getting traction off the line means a harder launch and better 60'. in the same sense that a good launch gets you to 60' down the track in less time, it would also get you to 1320ft down the track in less time than a bad launch (in theory). however, since you got there quicker, your car had less time to accelerate up to its maximum potential speed (trap speed). because it was accelerating for less time while physically within 1/4mi, it did not have enough chance to get up to a higher speed vs. a run with a good launch, BUT it got to the end sooner. this results in lower ET, as well as a lower trap speed."
still not seeing it. the car isn't accelerating when it's not moving. less movement = less speed. the fact that it's getting a good 60' time only means it's getting to that speed more quickly.
.....______
___|______\_____
|/-\_________/-\_|
