#1578099 05/25/06 01:30 AM
9
Does anyone know of a free software to convert .m4a audio tracks (iTunes format) into .mp3 format? I have looked all over and can't find any freebies. Thanks.
Metallic Steel Blue 99 SE Sport ATX college= few mods Infinity Kappas just added I have no secondaries! SELL ME YOUR WORKING IMRC box!!!
#1578100 05/25/06 01:51 AM
TGO Offline
jhymn will take actual itunes files and convert them to mp3. I dunno about files that were not generated by itunes.
1999 Silver Frost SVT #609 of 2760 Quaife, lightened SVT Flywheel, SPEC stage II clutch, removed resonator, k&n drop in - various other goodies too.
#1578101 05/25/06 04:47 AM
I assume you're using Windows.
ITunes can do it automatically, though it's a little clunky.
Go to Edit -> Preferences --> Advanced -> Importing.
Import Using: "MP3 Encoder"
Setting: (choose whatever bit rate you want, I use 320 myself)
click OK
then select whatever song(s) you want to convert, click the Advanced menu and then select "Convert Selection To MP3"
#1578102 05/25/06 05:08 AM
I thought .m4a was the protected format used by iTunes? If so, simply burn the files as a music CD, and import it as MP3.
'98 Contour SVT - Please pardon our dust, under heavy construction. '96 Escort LX - Pretender to the throne.
#1578103 05/25/06 06:50 AM
dBpowerAMP works great:
http://www.dbpoweramp.com/dmc.htm
Here's the link to the m4a (mp4) ---> mp3 codec that you need:
http://www.dbpoweramp.com/codec-central-mp4.htm (first codec on page)
Chris G. ~ 98 Mystique LS ATX
#1578104 05/25/06 01:32 PM
Those are .m4p (for "protected")
.m4a is MPEG-4 "Audio"
.m4v is MPEG-4 "Video"
.m4b is MPEG-4 "Books" (like a podcast, but they use .m4a too)
Those are non-standard uses, but are used by Apple, and therefore common.
Most just use the ".mp4" extention
Source
Goin' Round Traffic Circles @ 50Km/h!!! \m/ -- 1998 E0 SVT #2119 of 6535 \m/ -- 2003 Sentra SE-R Spec V
#1578105 05/25/06 02:46 PM
TGO Offline
it is. but for instance, if you rip music with winamp it can create m4p's too.
If you have protected itunes music you want converted to mp3, jhymn will do it as well as remove all the DRM stuff.
