Posts: 19 |
I had oversized valves put in my head, and if the exhaust and intake valves are open at the same time they can touch. So, I'm wondering if the VCT retarding could allow the valves to come too close.
If I want to check clearances, how many degrees does the VCT retard the exhaust cam?
'99 Turbocharged Cougar, Built motor in progress
Posts: 1,224 |
Good question.
Something to consider... You really don't want any overlap in a tuborcharged application. Why not just get a VCT eliminator?
BP
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies---
+++JRSC M62 Under Construction+++
My big-a$$ mod list.
Posts: 19 |
I thought that under WOT the VCT would not be activated, but if that is not the case someone please let me know.
CEG road warrior
CEG road warrior
Posts: 17,248 |
Only at deceleration the VCT is activated.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 1,687 |
I don't know why people even mess with that retarded VCT motor. '97 Silvertop owns you.
J.T.
2002 Chevrolet Silverado 294ci V8. Custom CAI, headers on the way...
1997 Mercury Mystique Zetec ATX
Deceased February 2006
Posts: 19 |
By "Owns" are you referring to the hydraulic lifters that require oil pressure?
Posts: 1,224 |
Again... Why not eliminate it?
VCT is just emissions crap and not performance.
I'm guessing that VCT will also hurt your spool time. It is letting pressure back into the cylinders instead of feeding your turbo.
BP
CEG road warrior
CEG road warrior
Posts: 17,248 |
BP
VCT effects performance when not working correctly.
Hector
257HP/259TQ
160HP/141TQ
Posts: 439 |
Originally posted by cbman: By "Owns" are you referring to the hydraulic lifters that require oil pressure?
Are you refering to those lifters that can be easily swapped for focus solid lifters/shims and outfitted with Focus performance cams/cam gears?
Ohsigmachi '96 GL MTX Zetec
--I don't won't to hurt you, but it's still on my list of things to do.--
View project Slippery Slope
