I have a noise I believe is a dry wheel bearing(front). no one wheel has any more noticible play. How can I tell Which bearing is the noisy one? (The one going Bad.)
Thanks for any help.
Sav
98 Mercury Mystique LS
sounds like both. they usually fail around same time so its a good idea to change both anyways. mine failed simultaneously.
'98.5 Black Ford Contour SE Sport 5-speed. All the SE Sport features with all the 98features that were supposed to be decontented for 98.5 '04 Silver Toyota RAV4 L Auto. Fully loaded.
Tony2005
Thanks, I was thinking it was the RH one cause when I turn right it goes away. the weight is coming off of the Right when turning right.
Thanks
Tony AKA Sav
I can replace the bearing in your knuckle for you if you send me you knuckle - see my signature.
What brand of wheel bearing are you using?
00 Mystique LS V6 ATX 57K miles K&N air filter TH Fix B&M 70268 Atx cooler
