#1575832 05/22/06 06:33 PM
Max02 Offline OP
I've done a ton of work over the last year getting my car clear of CEL's and running well again. I replaced the IMRC, MAF, and finally a new computer. The car has been running well for a few months now, but a few weeks ago I got the infamous P1518, secondaries stuck open, again. I tweaked on the cable a bit, and had AZ clear the code for me. It was good for a few weeks, but it did it again the other day. Once again I tweaked the cable a bit and had the code cleared. That lasted 4-days. I'm getting REALLY tired of this BS.
I thought I remembered reading that I could possibly clean the secondary valves. Is this what I should be looking at? Other suggestions? She's running great besides this. I may be selling her in the next few months (I've got an opportunity for a killer deal on a Maxima SE), and I would like to get this cleared up so the next owner doesn't have to pull their hair out dealing with this stupid code. Thanks!
2002 Nissan Maxima SE Former 2000 SVT Contour owner
this may be of some help
click here
98 CSVT 278 of 6535 Born: April 17, 1997 Black w/ Midnight Blue int Alpine CDA-9855; Type-R 6x8" (rear) Rockford Fosgate 6 1/2" 2-way comp (front)
Max02 Offline OP
Thanks! I guess I didn't realize IM was related. My mechanic has a cleaning they will do that covers all that stuff for $100. I'm going to give that a try.
I concur with this.
Berryman's B12 and a length of vac. hose that fits snug into the 'holes' (there's two of them) on the top of the UIM.
The car will NOT start (and will cut out whilst running) IF you take either of these vac. lines out from the UIM. Hence the need to 'fully then slightly pinch' the line with a vise grips -- to keep the engine running AND yet allow it to 'sip' the cleaner from out of the can too.
Note, B12 _doesn't_ make a lot of smoke ...but if you use "SEAFOAM" --- whoah baby! --- you have been warned!
Make absolutely sure that you re-insert both vac. lines SNUGLY into the UIM -- OTHERWISE the car will not start and/or may run very rough.
If everything works out well ...you WILL notice a difference in the 'stability' of the idle and in the ease of revving etc. etc.
Gerry
1997 Ford Contour SE V6 K+N Michelin MXV4's 95,000 miles
Max02 Offline OP
Thanks for the help. I had my mechanic do a thorough IM cleaning. Everything seems to be running well now, and the code is gone. Hopefully it stays gone. Thanks!
